HKS SC kit topic
Old 04-20-2017, 06:16 AM
  #1641
johnckeen's Avatar
Originally Posted by har-vey
its only a 300mm kit. if you spending the money at least go for bigger kit.will make you anything you want.
I have £500 barely, not £1200+
Old 04-20-2017, 06:30 AM
  #1642
Member
Bodyboarder1981's Avatar
these..... https://www.s2ki.com/forums/uk-irela...s-new-1171450/
and some good pads
shameless i know !
Old 04-20-2017, 06:32 AM
  #1643
johnckeen's Avatar
and some good pads
shameless i know !
I already have Performance Friction 2 piece disks with DS3000 pads Both donnington and silverstone lasted well but that was NA. I just want that bit more to cope with the 75% power gain.
Bodyboarder1981 (04-20-2017)
Old 04-20-2017, 06:46 AM
  #1644
Mr-T's Avatar
If your capped at around £500, you will be looking out for a set of second hand K-Sport or something. But will struggle to find something that doesnt need replacement pads / rotors for that money.
Old 04-20-2017, 07:18 AM
  #1645
UK Moderator
lovegroova's Avatar
A 75% power gain does not equate to a 75% speed gain (but I guess everyone knows that already ). It'd be interesting to see how much additional speed you gain at the end of the straights.
Old 04-20-2017, 09:27 AM
  #1646
Toms1989's Avatar
its only a 300mm kit. if you spending the money at least go for bigger kit. Freaky Parts will make you anything you want.
Pointless upgrade really. The discs are still the same size diametrically and width. The width is what allows for better heat dissipation, however I am not denying the pads need upgrading, OEM sized ones are just too small for this sort of power.
If you're really on a tight budget, get some Accord type R twin pot calipers and put some ducting in to cool the discs down.
ATR calipers can be had for sub £200. The pads are much bigger, the calipers bolt straight up to S2000 hubs with some minor dust shield trimming.
Pads specs of both
ATR:- 148.6mm length, 57.6mm height 17.8mm thick
EP3/S2000:- 135mm length, 52mm height 17mm thick.
Old 04-20-2017, 10:24 AM
  #1647
CynicG's Avatar
Your being quite troll-like these days LG. Good work keep it up
Based on my observations with MikeFifth last time at Combe, not a lot of top speed difference, just more push to get there. Will let you know again in a couple of weeks.
Old 04-20-2017, 10:26 AM
  #1648
UK Moderator
lovegroova's Avatar
I hope that didn't come across as troll-like, I'm genuinely interested, someone pasted some vids of Cadwell last year, and it was a good improvement.
Old 04-20-2017, 01:23 PM
  #1649
johnckeen's Avatar
I'm not saying its more speed I'm just saying you can't expect your brakes to cope just the same. Interested in the accord type r caliper comment, these fit straight on with no adjustment?!
Old 04-20-2017, 01:26 PM
  #1650
johnckeen's Avatar
Those ATR still rely on slider pins, I want to go away from those as they are just a pain in the arse to keep free
Quick Reply: HKS SC kit topic
