HKS SC kit topic
#1851
A lot of people drive S2000 less and less these days so I think its not easy to find one with HKS fitted and use it over 20K+ miles. I only drive 2000 miles this years
What did HKS say about the fault? Sending you a new one is great customer service but the issue hasn't been fixed. How could we know for sure it's not gonna happen again on the new kit?
Hendy took it back, sent it to HKS europe which then was going to be sent to japan. But the fault was pretty clear to being the same as the BRZ / my friends charger with the stripped threads.
Obviously nothing has been changed with the second charger i received so one would assume it will happen again. I really hope not.
Who's to say it wasn't caused by the flutter i experienced though? and if it was it shouldn't break again as i fixed that issue.
And if others who have the charger experience the same stripped threads will HKS offer a revised charger for owners?
I could be worrying over nothing, and i am in no way slating HKS, Just as it stands i cant recommended the product until worries have been put to rest.
boys2k (11-22-2017)
#1852
Originally Posted by boys2k
How many miles on the kit so far? I have the kit waiting to be fitted now i'm hesitating
#1854
Not sure, last person to tighten my belt was Chris at EFI, it was a brand new genuine HKS belt, and Chris had to make it pretty tight to stop it slipping, i marked the exact position in pen before i uninstalled everything, so its back to the same tightness that Chris put it to to stop it slipping
Pictures above (not mine) show the failure of the threads on the charger
#1856
#1857
I wonder if you could drill and tap two holes 180 degrees from eachother and fit two small grubs screws in there. Would prevent the housing from moving and the thread from being damaged. Only problem is room and whether it will put it all out of balance. If thats the issue that causes so many charger failures then HKS need to get it sorted. There must be a better solution. I did also think whether some decent loctite would hole the threads together more evenly and spread the forces. Would make it a bitch to dismantle thou
#1858
Got a HKS kit and AEM V2 and now trying to list what else I need in order to install - I dont track mine, will just for spirit driving...
- Walbro 255 fuel pump
- Deatschwerks 800 cc injector
- do I need regulator?
- Oil cool - any recommended brand?
- Hondata 4 bar map sensor
- NGK BKR8EIX
- Oil catch can - do i need this
