HKS SC kit topic
Old 03-09-2018, 11:47 PM
  #1971
Nottm_S2's Avatar
Originally Posted by johnckeen
why on gods earth is HKS traction fluid £198. That's daylight f-ing robbery!!
Wow. The rotrex stuff is expensive but not that expensive
About £100 iirc
Old 03-12-2018, 08:03 AM
  #1972
Mr-T's Avatar
Originally Posted by nomadicS2k
The recommended oil change interval is 80.000 km (50.000 miles) or every two years.
Link
Originally Posted by markforrester99
HKS manual says
Traction Fluid Filter Replace every 5 years or 70,000km.
Remember the above two statements are for different things. One is for the fluid, the other for the fluid filter.
Old 03-12-2018, 10:59 AM
  #1973
markforrester99's Avatar
On a side note. On inspection of my intercooler pipework i noticed that the pipe that comes out of the pressurised side of the supercharger (aluminium) which curves down to the cross brace/beam had been wearing on the edge of the steel work. Had probably worn through nearly half thickness. Might be worth a look on your kits incase it wears through.
Old 03-12-2018, 01:00 PM
  #1974
Define198's Avatar
Mine has done exactly the same, i believe i made a post about it earlier, i bought some rubber strip off ebay and covered the edge, plus put some more sticky foam (thicker) than the original that hks supplied as that had worn through completely
Old 03-12-2018, 05:28 PM
  #1975
noodels's Avatar
So one day it could get good -maybe ?
Respect.
Old 03-13-2018, 01:14 AM
  #1976
johnckeen's Avatar
I've checked mine, its not rubbed on anything, all its touching is the oil filter so not sure where you guys mean?
Old 03-13-2018, 02:35 AM
  #1977
Define198's Avatar
this was the main area i got rubbing, note the thicker rubber strip, also bellow near the cross member and bottom of the pipe also rubbed iirc.
Old 03-13-2018, 02:37 AM
  #1978
johnckeen's Avatar
Mines not touching there at all. Good fingers width of gap between those two pipes.
Old 03-13-2018, 06:42 AM
  #1979
boys2k's Avatar
mine is touching and i also use that.
Old 03-13-2018, 08:02 AM
  #1980
har-vey's Avatar
there is enough free play if you loosen all the joints to move the pipes away from each other. then re-tighten obviously
Quick Reply: HKS SC kit topic
