Honda Service History printout - cant tell me what was done!?
So I looked at s2000 from a dealer today.. (100% decided I want one now )
Service books is missing, and they have the last invoice from last year which included engine oil and diff oil change.
However they produced a print out since 2006 showing the car had its service and MOT from Honda each year.
However they said they cant check what was done at each service? Surely this is all on their system!? They tell me the engine oil would have been done each year but I have no proof?
It was this car..
http://www.autotrader.co.uk/classifi...iles?logcode=p
drove well, slight hole in softop which they would fix, quite a few scratches to the bonnet which they said they would buffer out, some loose trim on the passenger door, and some dull pain on the passenger side, 3 smallish sections of it which again they said they would sort.
One thing i noticed that where the hardtop sits on top of the car at the back it has caused the paint to be worn down right aroundwhere the rim of the hardtop would be. quite noticeable when the roof is down. i assume this is normal though?
It was this car..
UK Moderator
If you look in the FAQ, there is a printout of the service schedule which will show what they should have done at each service. Oil and filter is changed at every service.
UK Moderator
Well, it's not a positive, but if Honda have the printout showing when it was serviced by one of their dealers, then it's probably ok. I'd certainly ask for money off as it's all missing.
If you find out which dealers did the servicing, you could call them and find out.
the trim was just the seal at he top of passenger door. It wasn't so much paint loss as more if a dull marking when it sits on top of the car, it also felt slightly rough to touch. Guessing the hardtop as been on a while to cause this.
What also annoyed me a little was that they clearly washed it right before i arrived as it had lots of water marks, most likely to hide the swirl marks.scratches etc
Literally he had a piece of A4 with something like:
01/01/09 - Honda Reading - 36,000 Service
01/01/08 - Honda Reading - 24,000 Service
01/01/07 - Honda Reading - 16,000 Service
01/01/06 - Honda Reading - 8,000 Service
That was it, i asked if they can check the system to see what was actually done as for all i know they just changed a light bulb, and they said they dont have that info but it would have been per hondas standard service recommendations. I'd like to think that this probably makes sense, but id feel more comfortable having a ton of actual paperwork!
The previous owner has gone abroad so i doubt i cant contact her.
