How far back should the roof fold down?
Old 08-24-2007, 09:13 AM
jofes's Avatar
Default How far back should the roof fold down?
Is this as far as the roof is supposed to go down or do I need it looked at?
Old 08-24-2007, 09:15 AM
alex.stanley's Avatar
Doesn't look *too* bad I suppose...
Chastmeister has a problem with his too, which IIRC sits higher than yours when its down
Old 08-24-2007, 09:32 AM
Luke O'Zade's Avatar
For comparison, here's how far the roof went down on a car I had a go in recently. Not as clear a photo as yours but hope it helps.
AFAIK the extent to which the roof retracts can depend upon how warm it is. If it was a coolish day (and we've had plenty lately ) that might explain why it didn't go quite as far down.
Old 08-24-2007, 09:33 AM
shepp's Avatar
mine does that sometimes, its when the rear glass window does not fold into place correctly. I just put my roof up then down again and that usually cures it. or i gently fold in the window as the roof is going down.
Old 08-24-2007, 10:21 AM
Ste_Nova's Avatar
is it hitting the stoppers?
Old 08-24-2007, 10:24 AM
Shiskine's Avatar
As the roof is vinyl, it can get a bit stiff in cold(ish) weather. Either drive a few miles with the roof up and heater on to soften it up, or just try putting it up and down a few times.
I'd be surprised if the stoppers need adjusting ...
Old 08-24-2007, 10:30 AM
Phoenix S2k's Avatar
Tends to do it in cold weather or the first time if its not been down for a while. As suggeste warm it up with the heater and try again. When its cold and half way down the glass (04>) can stick, try easing it gently and continue.
Old 08-24-2007, 11:02 AM
Where do they live then? Might help Chas' situation..
Old 08-24-2007, 11:43 AM
Ste_Nova's Avatar
get a torch and have a look down the hole just behind the seat... look like a rubber 15mm bolt head
Old 08-24-2007, 11:55 AM
composite guru's Avatar
Jofes - Is you car a GT model?? I noticed that the GT cars seem to fold down further to allow the hardtop to be installed.
Just a thought.
My 2000MY used to sit high too.
Quick Reply: How far back should the roof fold down?
