Injectors...
Old 05-01-2014, 05:02 PM
gbduo's Avatar
Default Injectors...
Hey guys,
I have some RC 750 Injectors, I am not sure whether I should fit them or not. I am currently running the std injectors but the engine is running NA with the AEM ECU with BC Stage 2 cams, K&N, full exhaust system. If I put in the other injectors, would I get any benefit from the better spray pattern of the RC injectors and controllability when mapped with the AEM or would it be a waste of money remapping?
I honestly don't know so if anyone has any ideas let me know!
Cheers,
Graham
Old 05-01-2014, 11:09 PM
s2konroids's Avatar
Don't bother you've got Mor than enough fuel with 360cc and regarding the spray pattern there will be little in it, not worth hassle nor will yield any power.
Old 05-01-2014, 11:45 PM
BenRNBP's Avatar
Interesting to know the answer on this, I thought the mixture started to lean out with a few "stage 1" mods, so is this the Std ECU Map rather than the flow rate of the injectors that causes that or have I got the wrong end of the stick entirely ?
Old 05-02-2014, 05:38 AM
gbduo's Avatar
Yeh its the map and the ecu not being able to adjust for the increased breathing.
Thanks AJ. I'll put them up for sale then!
Sent from my GT-I9300 using Tapatalk
Gernby
01-17-2012 09:04 AM
chrisaltima
05-22-2011 01:55 PM
Bibbs
02-04-2009 02:17 AM
chairmnofthboard
12-06-2007 07:49 PM
s2konroids
05-29-2007 10:27 AM
Quick Reply: Injectors...
