Installed my aem wideband. Need advice
My car is fairly standard. Just an aem v2 intake. Installed the aem wideband today and the results weren't what I was expecting
Between 2-3.5k it's around 12 the. Leans out to 14 till 6k. A heavy lean spike to about 15.2 and back to 14 till 8 when it starts to heavily Richen.
From what I have read this is running faaaar too lean isn't it.
This is all during WOT right? If it was leaning out that much, you would feel a significant power drop, so its more than likely the wideband isn't reading correctly, or you are seeing those numbers at partial throttle
Sent from my HTC One using Tapatalk
Did you calibrate in atmosphere before install,was it a new wideband ?
Just the aem v2 intake. Standard ecu 1999 my. Engine is from an 04. Did the injectors change? I can't figure out why it runs so lean midrange. I was thinking fuel pump. But then it goes down to 11 near redline.
Member
Ok, how deep is it? If it's the same depth as the oem boss then no probs, but if it's spaced too far it may read lean. I'd also check your earth as it seems odd it would read this lean with limited mods. You could also go to an mot tester and ask them to check, or better still a dyno yes they can check under load.
