JDM Sat Nav, what's the deal?
I've done all relevant searches but the threads seem to just fizzle out without a conclusion as to whether the JDM Sat Nav can be made to work over here.
So does anyone know what the story is??
Can you just change the Sat Nav unit or is it built into the screen or what??
It is a factory fitted Sat Nav from honda by the way.
Thanks for any help.
Tuna
Tuna
Sorry I can't help you but I'd be interested in some advice on this as well.
When I asked Honda about it they advised me it would have to be a full replacement kit which would cost
It looks like a standard double din recess so why not bin it and fit an aftermarket system with TV tuner and DVD player, you could it up by fitting a PS2 while you are on
The electronics only work on jap radio frequencies, the interface is written in japanese and the maps are japanese.
A complete waste of time in the UK unless you fit a new aftermarket UK system and reuse the dash bezel.
Though IIRC the screen size is odd.
Haven't investigated it any further though.
As I understand it, the protocol codes are all different, so it'd be almost impossible to get it to work.
If it IS merely a double-DIN with a funny faceplate then that's your answer.
I understand that some NSX owners have done exactly that. But the sat-nav goes in a top bezel, rather than having to change to entire fascia.
I know you tried but try these!
https://www.s2ki.com/forums/index.php?act=S...ighlite=sat+nav
https://www.s2ki.com/forums/index.php?act=S...cs&highlite=jdm
