Josh's s2k build thread
#161
from your chart as you’ve said it’s set up now very similar to the CR ? Isn’t that the pinnacle of the s2000 and the best compromise for road and track ?
I thought the idea of running a bit more preload was so initially the spring has more load or higher rate on it to begin with ?
#162
Springs are linear <does not change KG rates as it compresses>
preload on these are to avoid bump stops.
CR have different tyres compared to others and has a little more oversteer.
Just saying swaping out the rear springs to all corners equal Kgs <if not a square tyre set up>transforms Ohlins on the car
#163
Thanks
#164
As I know what a gay bufty you are , I suspect you will want matching colour springs, so you will have to order them in from the Ohlins dealer you bought the kit from (or another Ohlins supplier).
On my car I went for Eibachs, as they are acknowledged as being one of the best springs available (with practically zero sag from compression over time), but they are a different colour:
#165
Ohlins Europe
https://www.ohlins.eu/en/products/au...8010-31--5766/
I put less price ones on mine, Faulkners 600LB=10.5 kg
Mike put Eibach on his Ohlins with a square corner set up.
#166
Wouldn’t doing this make the ride even harder on the rear ?
#167
#168
#169
Bodyboarder1981 (06-08-2018)
#170
And yes @mikert4 ..... will 100% need to be the same colour
