Diff bearings or wheel bearing?!
I've noticed a slight rumble from the rear of my car that is most audible about 50mph. I've swapped rear wheels with someone else to see if it was tyre noise, but it wasn't that. Before I go about replacing both rear wheel bearings, has anyone had the bearings in the diff go? It's definitely coming from the rear.
Its done 88k miles so not low mileage and is a 2009 car. Its more of a rumbling noise than whine. I'll drop the diff fluid over the weekend and see if its clean or not. I was just after some knowledge really on if the bearings in the diff are prone to going. I'll probably replace the diff oil then the two rear wheel bearings, after all.....its only another job I'll end up doing anyway at some point! ha!
As you're driving along if you dip the clutch does the noise change at all? The diff wont be under load at that point
i had a bearing go and it was more like rubbing a wine glass around the top and noise increased with speed
the rear calipers are very prone to sticking
Do you mean your wheel bearing went on yours or a diff bearing?
The diff went on my SC car and i've had a wheel bearing fail on my other S
the wheel bearing sounded like the wine glass thing
do you rear wheels spin free?
My diff had very little debris on the plug but it doesnt even turn freely so its proper fooked
If So.
I wouldn't rule out the possibility of pitting in the CV cups, on the CV joints nearest the diff. Is the car on coil overs / been lowered?
If you haven't done so already since owning the car, change the diff oil, its a worth while job and a good place to start !
Changed the oil and it was clean with no debris. Its not that bad but annoyingly I notice EVERYTHING! It is worse if I load the osr by doing a sharp left turn. So I think its the osr wheel bearing. Its certainly not bad enough yet to warranty replacing it. Yes the wheels spin freely, I'm pretty sure its a wheel bearing. Car is standard too. Thanks for the input anyway chaps!
vjarnot
03-14-2019 05:16 PM
BlueS2000Boy
01-09-2006 07:55 AM
