Key Fob no longer unlocks doors
Hi there, I have an original Honda s2000 and just recently I found that I'm unable to unlock the doors with my key fob. It hasn't failed in 15 years so I guess it was only a matter of time =)
When I press the unlock button, there are no "unlocking" sounds from either of the doors like there normally is. I replaced the battery in the remote but that didn't help.
Of course, I can manually enter the car with the key but then the alarm goes off and I feel like a burglar.
If something needs to be replaced within the car (actuator?), I can drive it to a dealership but how can I disable the alarm once I'm in?
Any help would be appreciated.
I may be wrong, but doesn't the fob also deactivate the immobiliser?? On my AP1 with the 2 button remote this is the case.
Strange that you can start the engine also??
There are recoding instructions in the technical FAQ if needed. (I also have a copy if you can't find them)
Cheers
Matt
Cheers
Matt
Sounds like the UK models are different? This was quite alarming (no pun) needing the remote AND the key so I just went out and checked:
My USA-spec '06 AP2 -- like all the rest of 'em -- fires up with just the key, the remote ain't necessary. The immobilizer transponder is built into the keys. (Just verified this with both removes 75 feet away.) Not sure how the valet key would work since there's no remove with it.
-- Chuck
-- Chuck
I would say a remote re-coding to the car is probably the easiest place to start to see if it enables your to deactivate the alarm.
You mention "both" remotes? Take it you have the same problem with both?? This would be unusual for the car to lose the coding for both of them.
The only other thing I can think of would be to remove car battery just to reset things and eliminate anything spurious on the car side.
Cheers
Matt
Cheers
Matt
I had the reverse, fob would unlock the car and disarm the immobiliser but wouldn't lock it. I thankfully I have the 2nd fob which works (though had to swap buttons round).
