Knocking engine, replace or rebuild
Old 05-04-2019, 02:43 PM
TangoVTEC's Avatar
Doh, bad news! At least now you can start afresh.
Recommend a thorough check/replacement of gaskets, pulley bearings and misc items on the new engine for peace of mind before you fit it.
The sealing/rotating parts on even the youngest engine will be 10 years old now.
TangoVTEC is offline
Jay Elliott-Purdy (05-07-2019)
Old 05-05-2019, 08:57 AM
There was a ready-to-go short block for sale recently, might still be available in “For Sale”. Delta Lima I think was the seller.
Might be worth considering if your top end is still good?
ValveBounce is offline
Old 05-05-2019, 12:14 PM
noodels's Avatar
^+ he would buy old engine..
noodels is offline
Old 05-06-2019, 12:34 AM
Daytona-Dave's Avatar
If you haven't damaged the bores then a good standard S/H crank and rod for the offending item as it will be trash then a refresh kit i.e new bearings rings and gaskets plus chain, check the oil pump and you should see a rebuild between 2 and 4k depending on how much work you do yourself
Daytona-Dave is offline
Old 05-07-2019, 01:11 AM
arsie's Avatar
^^^ is highly recommended to do the work. Congleton way I believe so a bit of a hike from 'the south'. Delta Lima is 50km NNE of Amsterdam.
Let us know how you get on could happen to any of us I guess letting the oil go is to be avoided ... see my avatar
If this were me I would be planning some time off the road/under the beast
arsie is offline
skool u
06-11-2018 10:41 PM
surfer_crx
05-16-2013 04:11 AM
shibby2000gt
03-24-2013 06:29 PM
nclaydon
05-18-2008 07:27 AM
pinoyk20
08-19-2007 09:18 AM
Quick Reply: Knocking engine, replace or rebuild
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
