Knocking from rear
Knocking from rear
Does anyone know the name of the adjustable drop link below the sway bar at the rear..its not the sway bar drop links as I've replaced those.Theres a knocking coming from that area and I think this is the culprit.it has a little adjustable nut and connects to lower wishbone.ive removed it and there does seem to be excessive play in the ball joints.
Also is it safe to drive with this removed as I wait on a replacement.
if you're removing it you have to remove all trace then the MOT man might not know
it's a pain in the ass and unless you have a ton of sand in the boot not needed. silly money from honda so people make their own
rsxtypes
10-10-2017 02:08 PM
Forza Minardi
12-03-2014 08:43 PM
