Leaking roof - Page 2 - S2KI Honda S2000 Forums
Leaking roof
Old 01-14-2014, 03:08 AM
You can try GTechniq i1
Scottland is offline
Old 01-15-2014, 01:40 AM
Joeh's Avatar
Originally Posted by TommoSilv View Post
I'd be interested to hear about this piece of nylon as I found something that sounds like you describe under the driver's seat. I thought it was a window squeegee or something, does this sound right? My drivers door is rattly to close when the window is down, whereas the passengers is fine and also have no leaks at all that side!
https://www.s2ki.com/...st__p__21209898
Chippo: I know you're saying it doesn't make much difference but it does help. Although its just a window glass stabiliser, try removing it and see the play in the window towards the outside of the car, it is quite important.
Everyones situation is different, for example your sons.
But you have to consider adjusting things isn't always the solution, it sometimes can be that you're making up for something else that is causing the issue. Sometimes a few things work in unison to provide a good seal, I'm pretty sure this is part of the package.
I find it to have solved quite a few leaky windows on the S2000, especially when they are leaking from the intersection of the A-pillar/window glass/roof corner.
Joe
Joeh is offline
Old 01-15-2014, 03:24 AM
sound_wave's Avatar
Those white things are £25 each from our friendly robbers!!!!!!!!!!
sound_wave is offline
Old 01-15-2014, 07:36 AM
I find parking nose uphill cuts the leaky seals down a lot.
RattyS2k is offline
Old 01-15-2014, 01:19 PM
CHIPPO's Avatar
Joe
As I inferred my comments are based on a huge survey of 2 cars!
And form the stats of this survey I deduced that the bits of plastic do not do a lot
1) Toby's car which has them fitted still , leaked and rattled
2) Mine that was sans the things doesn't leak , although it used to rattle
There you have the results of my analysis of the result of my survey , so not exactly a big study making a definitive answer I just offer my experience
So now what do you suggest one does instead of fiddling , I could have purchased new strikers where they are worn, along with catches , lord alone knows how much those
4 bits would cost . Fit new seals again cost
So being a fiddler , I looked at the problem and came up with a few possible fixes , my roof rattled and leaked from early on in the cars life , Honda never resolved it , I did. Lots of people fit bits of plastic hose on the hooks , I tried that lasted a week , the slotting of the catches is a well known badge and it helps, other have also packed the catches in the past
What did you do to cure all the cars with leaks and roof rattles ?
CHIPPO is offline
Old 08-11-2017, 01:19 AM
When thinking to waterproofing the roof consider the expert to do that with your car. As if you try to fix it without knowledge it will cause major damage to the car.So always hire the waterproofing contractor to fix the leaks well.
RomanHeber12 is offline
DaveUK
09-01-2016 09:15 AM
Simon B
08-01-2016 12:50 PM
Dracoro
07-04-2016 02:29 PM
nickkeyser
05-13-2016 10:47 AM
S2KiLLa19
04-11-2016 09:42 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
