Lesson Learned - Should Know Better
IF IT AIN'T BROKE DON'T FIX IT!
EDIT - you MUST change both lots of pads together.
Really impressed with my local Black Circles agent - been there twice for tyres and both time they've said check your nuts' torque after 50 miles, if you can't do it then bring it back and we'll do it for you - nice touch I thought.
Not that I even have a torque wrench... just interested
Sent from my C6903 using Tapatalk
It is all dependant on the type of torque wrench you use. Some will only work in a clockwise direction, so when you apply a reverse force on the handle it can have a negative effect in the internals.
Others are reversible, these are less of a problem but if you hear it click and you keepo applying force then you are likely to damage the mechanism.
If you know what you are doing then there is no problem.
