Liam-R S2000 build diary - Fast Road Car Build.
#23
Here are the specs...
Power Rating: 925HP
Wheel Dimensions:
Compressor: 66 mm BILLET 11 Blade Compressor Wheel
Turbine: 80mm inducer / 73mm exducer. Cast in Inconel 713 for high-temperature operation.
Housings:
Compressor: Standard Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
Turbine: .91 A/R Twin Scroll, with 'T4', Divided entry, and 4.21" v-band discharge.
#25
Yeah around then hopefully.
Got a feeling its going to be a huge kick as VTEC and boost come on line together, unless I enable the vtec a bit sooner.
Thats the least of my worries at the moment.. got to get the engine out first thats next weekends job though
#27
I've been reading a lot on upgrading engine parts as such, I dont plan on having a "built motor" as the yanks say, but I think ill be upgrading my springs and retainers as a minimum. I'll also be changing the oil banjo bolts to the newer design and adding a baffle to my sump.
This is going to be a road car. Purely for weekend fun on dry days only lol.
#28
Yeah that's all you really need to do for now but I have to be honest if you only want 500bhp then you have totally gone ott with the turbo. It will make for a crap road car as when it comes in you won't keep traction. If you were going drag racing then fine. A gt30 powered s2000 would leave you as the power band is optimal and controllable. The turbo you have you could run a 2.4l stroker and it would be a lot better. You upgrading diff, shafts or gearbox?
#29
Well I'm aiming for 500WHP but id be happy with 500 flywheel at first.
Yeah I know the turbo is capable of WAY more, and your right with the other turbo options but if I decide this one isn't for me, then I know quite a few people who want this turbo straight away so I'm pretty happy with selling it on and maybe downsizing. All I really want to do is keep up with my friends rx7 and s14. They leave me for dead on straights
Over time I will upgrade the diff etc, but this car is kind of pay as you go modifying at the moment. Wish I had the funds to purchase everything straight away but at the same time, I don't want to have everything there waiting because I'll get frustrated its not getting fitted lol.
