Light re-seal.
Hi guys, I'm getting condensation in my rear lights which seems to be the result of the rubber on the lenses. I've seen a few examples of people baking them with mixed results. Just wondering what peoples experience was of doing this, pros/cons and things to watch for?
thanks
thanks
Hi,
Before you dismantle your lights check the 2 gaskets aren't crushed or worn excessively. My rear lights were fogging up a couple of years ago, not badly but enough to warrant further inspection. The foam gaskets has started to go brittle and were obviously not fully sealing the lights. I bought 2 new ones and this solved my problem.
Might be a safer option before you break out the heat
Gaskets are readily available, i.e.: Rear light seal gaskets and easy to fit.
Hi,
Can anyone help shed some light on the correct lights gaskets for pre-facelift cars? The link above is for facelift and gives the option to order the required side. The 99-03 listing isn't sided..
https://www.tegiwaimports.com/genuin...000-99-03.html
And here's another listing, which doesn't mention models years...
https://www.tegiwaimports.com/genuin...0-ap1-ap2.html
I found this post suggesting they're not sided, but can anyone confirm? Lings doesn't have their parts diagrams up at the moment. Also, has anyone tried anything similar to the technique this person used, or has the foam been fine for most folks?
https://www.s2ki.com/forums/s2000-un.../#post24761340
Cheers!
Cheers!
