a long shot
but even still - 64k on a 7yr old *honda* engine!? im sure everyone has heard of honda's running on for well past the 300k mile range without anything as major as cams worn.
even fiats last longer than that! i might tweak that letter a bit - remove the bit about money/discount thats to blatent obvious. re-word it to sound more like "do you know this happened", "just for your info" etc.
Has the retainer underneath cracked allowing.... oh wait there. there is no retainer on the high vtec cam lobe.
I almost posted that an overev may have cracked the retainer however an overrev is unlikely to be the cause here.
Originally Posted by J_D,Oct 18 2007, 09:24 AM
It cant hurt for the price of stamp, you never know you may get a nice suprise.
Originally Posted by eSeM,Oct 17 2007, 12:14 PM
I don't think you will get anywhere with Honda UK with that letter.
Maybe knowing that letter writing skills are not a strength, and no shame in that, it would have been wise to seek advice as to compiling a business-like concise letter devoid of chat, flannel or emotion.
A brief opening & then the key areas of complaint set out as 'bullet points' makes for rapid understanding. Setting a date by which you expect a response, following up with a further letter can work.
In it's current form it makes it too easy for Honda to just submit a standardised reply. But good luck.
But is this a lesson not to buy an Import?
I note that within other clubs such as the MX-5, budget imports are seen as the poor relation much to the irritation and consequent huffing and puffing of their owners.
Member
Not sure its an import issue - this could happen on a UK car and you still wouldn't get a penny from them.
Once the car is out of warranty, they really dont care.
You'd get more help if the car is a UK supplied car on a goodwill basis. On an import that Honda Uk didn't get the revenue from in the first place i'd say your chances are pretty much Zero.
I don't understand why people think that the s2000 engine will do the same mileages that other honda engines will do. It's a much more highly tuned power unit that revs higher than any other honda engine. We've seen on a number of occasions that the F20C will often let go once it gets to the 120-130k miles. I'm sure some last longer, but is certainly not an engine that will do 200k miles as a sure thing.
I agree;
I tend to think the average engine probably averages 3,000 rpm for most of its life.
I'm sure mine averaged nearer 6,000 rpm for a lot of it.
Wear rates increase proportionately, and stresses often have a square function.
If you want long life, but a diesel.
