Modirfy Shift Beep Fitting
Old 08-15-2017, 10:09 AM
Fatbloke's Avatar
Default Modirfy Shift Beep Fitting
Can anyone tell me which wire the tacho signal connection connects to on the ECU?
The UK instructions on the Modifry website bear no resemblance to the colour or layout of wires on my car
Old 08-15-2017, 11:42 AM
seatonsurfer's Avatar
Have a look at this thread to see if it helps https://www.s2ki.com/forums/uk-irela...hd-s2k-258426/
Old 08-15-2017, 11:49 PM
kw_21's Avatar
Start again. Disconnect all the wires, lay them across the right palm, then lay the shift beeper on top of them. Now clench your fist slightly, bring your arm back over your shoulder and launch the damn thing over the garden fence! You don't need a shift beeper on public roads....
And change you signature from Moonrock to Trotter Yellow
Old 08-16-2017, 12:49 AM
Fatbloke's Avatar
For some unfathomable reason I seem to be drawn to unnecessary things that make irritating noises
Old 08-16-2017, 04:15 AM
Jerry_Attric's Avatar
Having just fitted one of these units to my MY06 (DBW) I thought it might be useful to record the problems I encountered and the solutions.
The first difficulty was getting a decent electrical connection using T-taps. In the end I got the trusty soldering iron out and fitted bullet connectors - that resolved that problem.
It took some time to work out which cable to the ECM to connect to for the rev counter pulse, as this is quite different to the pre-DBW models. Ultimately I realised that the Modifry fitting instructions for CR models refers to a connection to the ECM, and when I checked my car, the cable layout was very similar. So the cable required is the blue one in the top connector (connector E) into the ECM, and is as shown in Modifry's photo of the cables for the CR.
I have attached the Redline unit and bleeper to the outside of the driver's footwell, tucked up out of sight behind the dash. The earth connection and the ignition switched feed has been taken from the black and yellow cables respectively that attach to the unit (I'm not sure what it is) tucked up just behind the dash on the far right hand side.
As others have said the bleeper is very loud, and I may put a piece of tape over it, but it works very well, and it does mean that you can forget about checking the rev counter as you near the limit, and keep your eyes on the road (or track).
Does this help?
Mike
Old 08-17-2017, 01:23 AM
Nick Graves's Avatar
Nice one!
If you use proper OEM-style crimp connectors, you don't actually need a soldering iron. Some people maintain that modern lead-free solder is a bit too brittle for use in a vibratory environment. I've not had a problem (yet) where I've solder-spliced into an existing wire, though.
If you want to fit a beeper, why not? There is one in the 86 and it's quite handy. Might save a few rods exiting block right...
Old 08-17-2017, 01:30 AM
richmc's Avatar
I've got one of those, one day I'll divorce her.
Old 08-17-2017, 03:18 AM
Fatbloke's Avatar
She'll get in first if she knows what's good for her
Old 08-17-2017, 03:40 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
As per my comment in the linked thread I consider this device nearly essential if the car is supercharged or has a Gernby tune. Revs climb so fast in my car (now) that I'm always bumping the rev limiter without it. Eyes out the windshield, not on the dash. Beep-beep-beep -- Shift. (In first and second it's Ring - Shift!)
-- Chuck
Old 08-17-2017, 03:51 AM
CynicG's Avatar
-- Chuck
Good point this. I actually have obscured my rev counter with the steering wheel/boss combo which is annoying so have been listening to the engine for changes and at times get it wrong. I think I want a led rather than a beeper though as I still like hearing the engine note.
Bunnierabbit6
12-14-2013 05:13 PM
kikicha
10-19-2006 12:44 PM
chriztopherkent
07-21-2004 06:55 AM
M@verick
04-29-2004 03:55 AM
Quick Reply: Modirfy Shift Beep Fitting
