Mase tuning visit
Mase tuning visit
Hi all, i am sure many of you know who mase is by now, he is coming over late march and will be tuning on the 25 and 26th of march, and maybe another odd day after dependant on numbers, before we go to spa and nurburg
if anyone is interested and need a health check, tune, tweak let me know, or if anyone is after an AEM EMS, Flash pro also let me know if needed for the tunes
phil
phil
Unfortunately Rob you can't do it on the stock ECU, if you need an ECU PM Phils2k or see whats lying around :]
You'd probably need a full tune rather than a tweak though.. not sure ask phil? >___<''
I will have my exhaust, decat, header & K&N on by then so I could probably do with a full tune - any ideas on cost?
Also, where in the country does this take place?
Originally Posted by rob2.2,Feb 14 2011, 12:00 PM
what tweaking can be done to a stock ecu or do you need a flash pro?
1. Kpro
2. Greddy EMU, which can be picked up cheap and is more than enough for what you need, if you can get someone to 'properly' tune it they work extremely well - i have one but require time to get right.
3. VAFC 2
If you don't want to spend too much cash and want a good increase then get that cheap VAFC2 (looks like wayners is prepared to take offers in the FS section ). Providing it doesn't run too lean and doesn't knock as when you remove fuel via map sensor voltage it advances timing, generally you want to add timing but not everywhere and be careful.
It's cheap,reliable,works properly both N/A and boosted and doesnt require any harness adaption ect. Will be all the ECU you will need.
