MeisterR ZetaCRD
I think from memory the difference between the Zeta R and S was just the adjustable pillowball top mounts which dont apply to the S2000 anyway. Looks like this is exactly the same with the CRD and CRD+
In my opinion i would see if they have any of the old sets available at a discounted price.
I actually bought the Zeta R instead of newer CRD as the CRD are a slightly softer spring rate and matching valving I believe. I wanted the slightly stiffer setup of the R for track work and it was approx £150 cheaper than CRD I think.
Sadly it looks like the Zeta R is now out of stock for the S2000.
Just noticed it mentions the Zeta CRD are only available for S2000 AP1 1999-2003. I'm assuming they would also fit the facelift '04 onwards no issue ?
Spend a bit more on KW V2s or Bilsteins. Meister R's are cheap and cheerful, if you're paying someone else to fit and do the geo that will be more than half the cost. May as well do it with something of reasonable quality.
mtunreal (07-06-2017)
