Might get a unichip
Each to there own.
Its personalization, theres many of us who dont mod and many of us who do.
Its like having a PC and modifying (adding RAM etc) that to run games better/faster etc, but you dont have to. (Poor analogy but you know what i mean )
I can understand your point though.
Personally i find it fun and interesting.
Originally Posted by MB,Oct 23 2007, 09:10 AM
5250 IIRC?
With the basics (exhaust, de-cat) Headly @ Millway set mine (with a VAFC) to about 5250 and smoothed out the dip at cross over.
With the snail, Mase set the point at 4500 as it was best for the amount of air being flowed.
I can see the advantage of this with the gears as with them being shorter, it'll be harder to keep the car "in the zone".
Not sure I could handle having a 150 top end though, as that would be a killer on long drives. I'd need a 7th gear (I sometimes feel I need one now).
Member
When you said where the power curves cross, I assumed you meant pwoer and torque - due to their relationship they will always crossover at the same rpm on any car and dyno. I think it was 5250.
Its a good way to spot a fudged dyno plot.
UK Moderator
On a standard car, when you change up a gear at max rpm, it drops you back to the bottom of the VTEC range, does this still occur with new gears? If not, that would be a good starting point for VTEC engagement, alternatively, probably 500rpm lower wouldn't be a bad idea.
