move direction
Hi Guys problems.... not many.
Ok car is 54 plate. Has had MOT and all back on the road new brakes complete plus wheels all done wheels balanced 18 inch. When accelerating hard in most gears as soon as you push clutch down to change, the car from the rear moves of line and you need to anticipate with slight left steering correction. Any ideas as what the cause is? cheers guys. |
Usual suspects...
Tyre pressures, tread depth uneven, alignment not quite right, dragging caliper. |
So as you unload it moves?
I would start with bushes / rear tie rod, maybe a bearing - if it didn't do it before the work was done i'd suspect a wheel not quite on straight or a tyre not balanced quite right. If its new wheels AND tyres .... i'd suspect the geo needs adjusting for the new wheels and tyres. |
Is it a sliding motion or a yawing/twisting motion you can feel?
Sounds like it could be geo out of spec or a draggy rear caliper. One of my rears was sticking badly when i got the car out of hibernation last spring. Whenever i backed off the throttle i could feel a pronounced yawing sensation through the chassis where one rear wheel was being braked all the time. |
as you engage the clutch you disengage drive, this makes the car level out potentially if you've been on the throttle, that would reduce rear end grip and increase front, potentially tucking the nose in and slipping the arse end out. plus the car has that passive rear wheel steering thing
if it's in a straight line you just need to check tyres - condition, pressure, matching and and then if all ok alignment my car was transformed after a good setup. i think the S is very sensitive to poor alignment |
Pump your tyres up you cock!!
Originally Posted by AquilaEagle
(Post 23594369)
though possibly more to do with Bernies driving style than a mechanical issue ;) Cue the ford traversing S2000 video :LOL: |
All checked..nope cheers.
Originally Posted by chrispayze
(Post 23593812)
Usual suspects...
Thanks you two....i think new bushes but man loads of cash...
Originally Posted by mikey k
(Post 23594541)
Normally it's a brake caliper binding.
