move direction
^^^^ same as. After a spirited drive, hovering a hand over each wheel suggested one was considerably hotter than the others. Turned out to be the sticking culprit
Hi Guys problems.... not many.
Ok car is 54 plate. Has had MOT and all back on the road new brakes complete plus wheels all done wheels balanced 18 inch.
When accelerating hard in most gears as soon as you push clutch down to change, the car from the rear moves of line and you need to anticipate with slight left steering correction.
Any ideas as what the cause is? cheers guys.
i had this after fitting coilovers on my drive, it wasnt level, didnt realise my drive was slightly wonky, took it for alignment and it was all strait on the hunter, but went for a drive and it would do this change of direction
tjhmortimer
05-28-2015 02:23 PM
