Muz Mats - Roof well mat
Definitely getting some Muz mats for the footwells.
I have an 04 car and was wondering if it is worth getting the roof well mat as well.
Am I right in thinking that although it will fit my car it was specifically designed to reduce scratching on the plastic window variant (mine's glass). Does it reduce road noise? I don't want to get one if it is of no benefit. Would rather spend it on something else.
Cheers
Martin
1 Post
I made my own not long ago from some material you get in Halfords for covering sub boxes. Through trial and error I made a paper template and then used that to cut out the right shape. I then stuck it down the double sided tape.
If I did any cutting with a sharp blade I would end up looking like your avatar (Minus a few digits ).
Why did you make it, apart from the cost issue? Was it to protect the window or did you notice an increase in sound proofing?
Cheers for the advice, worth looking into though
This cut down the noise a lot and stops it moving around.
Not that a later car glass window needs protecting, just finishes the area off nicely.
