Neglected... for 4 years - S2KI Honda S2000 Forums
Notices
Old 07-11-2018, 02:06 PM
Default Neglected... for 4 years
I may be acquiring a 2005 S2K. It’s low mileage, cheap... and has been sitting on a driveway, uncovered and not driven for the last 4 years. Last MOT was 2014. MOT history is clear before that. It’s in need of considerable care and attention! So, where would you start? What’s likely to require replacement? I haven’t had chance to give it a proper inspection on a ramp yet.
Any relevant threads you can point me to?
Any advice appreciated (from an MX-5 owner!)
mxfiver is offline
Old 07-12-2018, 12:05 AM
richmc's Avatar
Geo bolts likely to be seized, you may need to have all the bushes replaced that's around a grand.
richmc is offline
The Following User Says Thank You to richmc For This Useful Post:
mxfiver (07-12-2018)
Old 07-12-2018, 12:17 AM
Nottm_S2's Avatar
I would change all fluids before it's driven
engine oil & filter
Gearbox
Diff
Coolant
Brake fluid
Then you'll need to free off the brakes I guess
Probably new tyres
And as Rich says the Geo bolts may be rusted up
Nottm_S2 is offline
The Following User Says Thank You to Nottm_S2 For This Useful Post:
Old 07-12-2018, 12:31 AM
richmc's Avatar
A visit to Dr.MX5 would be in order to get it undersealed when it's all sorted.
As Nottm said fluids first! I would consider getting it low loaded to a good independent garage main dealer will be far too expensive and not many of them know S2000 anymore. Unless you are considering doing it yourself of course.
Hope he hasn't had the handbrake on all that time, it will be like a dog going across a carpet.
richmc is offline
Old 07-12-2018, 01:45 AM
chrispayze's Avatar
There was a similar 'barn find' type thread a while ago with lots of good tips. Worth a search.
chrispayze is offline
Old 07-12-2018, 01:49 AM
2005 the best model year so you're doing well either way ;-) what colour it be?
fullleather is offline
The Following User Says Thank You to fullleather For This Useful Post:
Old 07-12-2018, 04:34 AM
Some very helpful advice. Thanks, guys.
Colour...it's kind of a mossy black...
I'll have a hunt for the barn find thread.
mxfiver is offline
Old 07-12-2018, 09:06 AM
Sipha's Avatar
Interesting ! Does there appear to be much corrosion visible ? how many miles does it have ?
Sipha is offline
The Following User Says Thank You to Sipha For This Useful Post:
Old 07-12-2018, 09:28 AM
unclefester's Avatar
Have a feel inside the rear ;lip of the rear arches, check under the sills for the grommets in place and have a good poke around under the bonnet - all for signs of tinworm. Also inspect the join between the sills and the rear quarters.
unclefester is offline
The Following User Says Thank You to unclefester For This Useful Post:
Old 07-12-2018, 11:27 AM
And pictures!!!!!!!
martin j is offline
Quick Reply: Neglected... for 4 years
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
