O2 Sensor Values
O2 Sensor Values
I'm trying to get to the bottom of my annoying hesitation/kangaroo problem so purchased an OBD2 display (Ultragauge My link) so I could see what the sensors were doing.
The primary o2 probe values seem to jump all over the show compared to the secondary, but as I'm no expert I'm not sure how to interpret the data
Obviously, when I'm observing these changes the running conditions are stable, stable revs, load etc.
It jumps around anything from 0.000v to 0.915v then back to 0.215v for example just at a steady idle.
Am I correct in thinking that when in 'closed loop' mode the engine fuleling is based on the feedback from this sensor? (amongst others of course). Wondering if it's the culprit I'm looking for.
Any help welcome!
nb: Heatsoak, although a real problem for S2000's is not the cause here as it happens on the way to work after 5 mins, when the intake temp is cold.
Any help welcome!
Thanks s2konroids, but if I could just pick your brains a bit more...
How about when at a steady idle? I thought that 0.2v is lean, but 0.8 is rich so is my ECU 'hunting' to find the pefect mix all the time and failing miserably?
I know I'm probably a muppet but surely if conditions are stable the reading shouldn't vary wildly.
Cheers
Cheers
just had mine diagnosed as faulty[now fixed],the vehicle electrician showed me a picture of how the sensor should work on the oscilloscope.it should fluctuate between 0.1v and 0.9v at regular intervals[basically up and down between those two values].
Can I be nosey and ask what your fault was/symptoms were etc? Always interested to learn a bit more...
Member
Originally Posted by s2konroids' timestamp='1348145683' post='22025425
In partial throttle yes should jump around, wot no.
Cheers
Being lean / rich for these short periods if fine, and how all car engines work.
It bounces faster at cruising speeds.
Member
If you know what you are looking for, and OBD or reading direct from the sensor can be useful, but if you do see odd readings it could be a number of things.
For example closed loop fuel control doesn't just take inputs from the lambda sensor, it will also look at coolant temps and MAP / MAF readings. If one of those sensors is screwed, this will influence the AFR reading. So you often don't know if it's chicken or egg.
Don't know which direction to go now though as I've been through all the FAQ's, cleaned IACV, MAP sensor, throttle body, had valve clearances done properly, eliminated heatsoak yet it still happens, which is why a varying value looked like a culprit, oh well, the quest continues...
MB I agree, the reader was only $60 from the states and has at least let me see into the cars' brain. So far all the values check out though, so thinking cap on!
