Odd noise coming from the rear end of the car
Originally Posted by RobinA3' timestamp='1441125242' post='23733420
Gave the hub nut a bit of a tighten, was only able to move it about 1/8th of a turn but seemed to have solved the noise.
That was a HELL of a noise for hub nut being an 8th of a turn loose. And how did it get that loose anyway? Are they not staked / locked?
Honda even released a TSB.
https://www.s2ki.com/s2000/topic/929...e-nut-tsb-diy/
Originally Posted by heymynameismark' timestamp='1441180583' post='23734176
[quote name='RobinA3' timestamp='1441125242' post='23733420']
[/quote]
Wow, thanks for that. Interesting!
Something I should get on to doing soon.
Dealer torqued the nut correctly, staked it and the car did another 45k miles before i sold it without it re-occuring.
You'll probably find that the splines are rusty, hence the loud noise. You need to put a new nut on it, torque it correctly and whilst your at it its worth greasing the splines.
If you remove the hub nut you'll find that you can slide the shaft a good way through the splines, certainly enough to work some grease into the splines.
Its the shaft moving slightly in the splines that makes the noise. That's why people often notice a click when the pull away.
