Oil Change - Filter stuck
#22
Originally Posted by Si2k,Aug 25 2007, 10:38 AM
Yes cause only mechanics know how to do an oil filter change ?
Make sure you tighten it up properly when you fit the new one, hand tight isn't enough and you don't want it rattling off.
if you do screwdriver it mak sure you dont damage the thread or sealing face of the filter.
Good luck
Good luck
Maybe boring but sometimes experience is worth something ? and in the long run could actually save you all the money you thought you had saved doing it yourself.
#23
Good luck
Good luck
#27
Originally Posted by RobJ1,Aug 25 2007, 05:30 PM
Again thanks for everyones help. Next the brakes Might take that one to the pro's and assist in the change.
#29
Originally Posted by AquilaEagle,Aug 25 2007, 05:40 PM
"as long as the screw comes out it should be straight forward"
#30
1 Post
Originally Posted by RedUn,Aug 25 2007, 09:18 AM
Everyones got to start somewhere, theres only one way to gain experience and it's not by paying someone else to do it.
I've never had a mEchanic touch my car since brand new, all work is done by myself to a lot higher standard than Honda.
Goodluck Rob i'm sure you'll sort it
Rick
Rick
Glad to hear you got it sorted in the end.
Question for those in the know. If you do an oil change should you always change the oil filter?
