Oil sump change issue
Hey peeps, i was swaping sumps (baffled on one that i wanted) and when i was doing the second one noticed one of the dowel pins had stuck in the sump and not the block like the other one so it is missing on the one i had swapped. It is the one on the front of the sump. I have no problem taking it off again, its just time tbh as i haven't put any oil in it. Just wondering if it matters or not?
The dowel pin is number 18 on the pic below but for some reason it doesn't show the second one. You can see the hole it sits into just in front of bolt numbered 20 though.
That's a ring pin not a dowel. Can't see anything that the accuracy would affect the seal.
That said get a tin of degreaser/solvent and clean, clean and clean again all surfaces.
Any oil on sealant surfaces will stop the bond of the liquid sealant sticking to the surface and give you a weeping seal
Just out of interest is it difficult to change the sump using axle stands?
Is it a case of undoing all the bolts off prying the sump clear from the block and then fitting new sump (fitting a baffled ballade sports item). From the parts catalogue i see no sign of a rubber gasket which is a relief because my old integra pissed oil out of the sump even when new gaskets were fitted, the steel was so thin for the sump pan that it warped and bent over the years.
Had no problems with other cars that used a gasket sealant between the two joints so i was pretty glad to see that this is how the S2000 works. Im fitting a baffled sump as im going up to a more track orientated tyre and want abit of extra piece of mind.
Glad the S2000's sump is the same as the Rover's k-series engine as it makes removal and re installation a doodle!
johnanderson
02-19-2011 09:10 AM
