..Pacing up and down
Old Feb 4, 2010 | 03:06 AM
andy2000's Avatar
Default ..Pacing up and down
Car is with TGM Fleet to check geo. 98,000 miles and 6 years without being looked at, will the bushes be seized or not. ??
I have a feeling I'm going to need to find a load of cash quite soon
Old Feb 4, 2010 | 03:07 AM
lovegroova's Avatar
You might get one or two, I'd be surprised if it were more than that. Good luck!
Old Feb 4, 2010 | 03:10 AM
Wobbly's Avatar
My S is the same age, although 40k miles less, and only one bolt was difficult to remove. It seems to be a complete lottery, fingers crossed for you.
Old Feb 4, 2010 | 03:16 AM
S2000Si's Avatar
One or two i'd say.. difficulty is that if you add a replacement polybush because of a siezure, you have to replace the equivalent opposite side with a poly bush too.
but i'd also bet you have a dead compliance bush or two
Old Feb 4, 2010 | 03:27 AM
Rob88's Avatar
I'm going to bet on 4 or more.
Old Feb 4, 2010 | 03:34 AM
eSeM's Avatar
Old Feb 4, 2010 | 03:56 AM
mikey k's Avatar
I'd bet on two front caster bolts minimum
Maybe one rear camber as well.
Old Feb 4, 2010 | 04:03 AM
WinFreak's Avatar
I had the same bet on last month, my04 with 19k miles and I had 6 seized ones
Old Feb 4, 2010 | 04:11 AM
punchdrunk's Avatar
I bet none
Old Feb 4, 2010 | 04:34 AM
S2IM's Avatar
MY02 (26k), sorted at WIM recently. None seized Hope you'll be fine!
