A Pillar trim broken stud/clip
I'm unable to replace the interior trim on my driver's side A pillar (having removed it to install some dashcam cabling). It looks as if the upper stud/clip which clicks the trim into place is broken. Does anyone know if it's possible to replace one of these studs, or whether I need to buy a whole new piece of trim?
Also, any tips for a reasonably-priced source?
If only you could buy that trim on Ebay for not much money ... imagine that.
https://www.ebay.co.uk/itm/Honda-S20...4AAOSwAQBaqoMp
https://www.ebay.co.uk/itm/10x-Clips...cAAOSwK~RaK8nm
These don't look exactly like the clip that's broken (the middle disc is the widest in my broken clip, whereas the upper disc is the widest in the eBay clip), but I'm guessing that they would do the trick for the A pillar?
Is it the clip that you've killed or the piece on the trim that retains it?
In which case just buy the clips and don't worry about it - i generally keep a mixed box of trim clips around when i'm working on the car as they get brittle with time and snap / rattle / fall off etc.
IIRC this ( or very similar ) is what i keep around.
https://www.ebay.co.uk/itm/415x-Car-...IAAOSwO9JZ9MWs
The white clip in the middle row is the closest to the clip that's broken (but not identical) - in fact it looks the same as the other clip that I found on eBay. If that set works for your then I guess that it'll be fine for my pillar
