A Pillar trim broken stud/clip
Old 04-30-2018, 01:35 AM
itm
itm's Avatar
Default A Pillar trim broken stud/clip
I'm unable to replace the interior trim on my driver's side A pillar (having removed it to install some dashcam cabling). It looks as if the upper stud/clip which clicks the trim into place is broken. Does anyone know if it's possible to replace one of these studs, or whether I need to buy a whole new piece of trim?
Also, any tips for a reasonably-priced source?
Old 04-30-2018, 02:09 AM
unclefester's Avatar
If only you could buy that trim on Ebay for not much money ... imagine that.
https://www.ebay.co.uk/itm/Honda-S20...4AAOSwAQBaqoMp
Old 04-30-2018, 02:22 AM
itm
itm's Avatar
Thanks for that. The eBay thought occurred to me in the meantime, so I tried hunting down the clips (which I hoped would compete favourably with £26 for a pair of new trims). I found these:
https://www.ebay.co.uk/itm/10x-Clips...cAAOSwK~RaK8nm
These don't look exactly like the clip that's broken (the middle disc is the widest in my broken clip, whereas the upper disc is the widest in the eBay clip), but I'm guessing that they would do the trick for the A pillar?
Old 04-30-2018, 03:06 AM
Is it the clip that you've killed or the piece on the trim that retains it?
Old 04-30-2018, 03:07 AM
itm
itm's Avatar
Just the clip - the hole in the trim looks fine.
Old 04-30-2018, 03:11 AM
In which case just buy the clips and don't worry about it - i generally keep a mixed box of trim clips around when i'm working on the car as they get brittle with time and snap / rattle / fall off etc.
Old 04-30-2018, 03:12 AM
itm
itm's Avatar
Yes I think I'll go for those eBay clips (as per my previous post). They don't look exactly like the clip that's broken, but hopefully close enough. Thanks.
Old 04-30-2018, 03:18 AM
IIRC this ( or very similar ) is what i keep around.
https://www.ebay.co.uk/itm/415x-Car-...IAAOSwO9JZ9MWs
Old 04-30-2018, 03:21 AM
itm
itm's Avatar
The white clip in the middle row is the closest to the clip that's broken (but not identical) - in fact it looks the same as the other clip that I found on eBay. If that set works for your then I guess that it'll be fine for my pillar
Old 04-30-2018, 03:36 AM
devon2k's Avatar
Car Trim Clips & Fasteners - Trade Prices - Vehicleclips.co.uk
These people may be able to help
Quick Reply: A Pillar trim broken stud/clip
