PowerFlex Bushes !
PowerFlex Bushes !
Hey guys !
Where is the best place to buy powerflex bushes at sensible money? I require a complete set of the standard powerflex for the whole car !
Fleabay have a few sellers doing a complete set HERE is one, not sure on the pricing though ! Any dealers with discount avaliable?
Also can anyone advice on the sizing of the following bushes for an MY08 AP2
- Front anti roll bar bush.. either 26.5mm & 28.2mm
- Rear anti roll bar mount.. either 25.4mm & 27.2mm
- Rear upper wishbone bush.. either 35mm or 42mm
Thanks guys !
Thanks guys !
I would think carefully about doing All in poly as it may detract its value
I went with full Strongflex polybushes, have no issues and is practically OEM.
I did my entire suspension in Powerflex purples and I have been very happy. I used their newer spherical style compliance bushing along with the stainless bolt kit for it as it is prone to corrosion, and have had no issues in 3 years.
I ordered from Camskill which were cheapest at the time. Consider refurbing your arms & ARBs with POR-15 or similar at the same time.
Useful chart found here: https://www.s2ki.com/forums/s2000-br...prings-818884/
Shows that 08 Front ARB= 27.2mm
Rear= 25.4mm
However i notice Powerflex don't make a 27.2mm front. Might be worth checking that on the car, or using their 27.2mm rear for it because I think the mounts are the same front and rear, it should fit.
I can't find solid info on rear upper wishbone size, however I checked my receipt and I used a 35mm for my AP1 suspension so I'm pretty sure yours will be the 42mm.
Rear= 25.4mm
Winstan (07-09-2017)
Many thanks for all the feed back guys ! Will most likely be doing the rear first and then the front, as I'm dropping the subframe out this winter for some de-rusting !
Rear= 25.4mm
Rear= 25.4mm
Finally remembered to get the callipers out and measure for myself, and can confirm:-
AP2 MY08
Front ARB= 27.70mm
Rear ARB = 25.70mm
Rear upper wish = 42mm by 57mm
Solid advice on the front ARB size, closest Powerflex do is a 28.2mm. I will give them a call this week and see if the bush is satisfactory when clamped. If not will order a rear set for the front !
Thanks Again !
Not sure if you're still looking mate but I just noticed this advert from Driftworks:
https://www.driftworks.com/powerflex-poly-bushes/
Powerflex deal ending Friday night. Use our new improved Powerflex site and add to cart to save 5% on 1 pack, 10% on 2 packs and 15% on 3 packs or more of Powerflex bushes
