Problems starting
Old May 13, 2008 | 03:10 AM
juventino's Avatar
Default Problems starting
A couple of times I've had problems starting the car, once at a petrol station after filling the car. The first time I stopped the car and after a minute or two tried to start and it wouldn't.
I do the usual starting method, but when I press the start button the starter motor goes but the engine does not start. It's not the battery. I noticed the second time after a few minutes of not starting two lights on the dash flashed (one was engine, the other something next to it I cannot remember) and then it started. I checked the fuses and they seem all okay. I tried the methods as described in the instruction manual.
Any ideas?
Thanks
Old May 13, 2008 | 03:36 AM
RISLAR's Avatar
More info please!! how does it run in the rev range, any missfires, what fuel are you using? is it due a service?
Old May 13, 2008 | 04:13 AM
juventino's Avatar
It had a service about 800 miles ago. When I'm driving it there's no problem whatsoever - fine through revs from 0 - 9000 in all gears. No miss-firing. Recently I put in quarter of a tank of 95 octane from some independent petrol station but most usually it's 97 octane from Sainsbury (which was the last fill).
I kind of wondered if it was the engine flooding - but I followed the instructions in the manual and nothing really happened. The first time I just left it for 20 minutes and it started. The second time it started after 5 minutes.
Old May 13, 2008 | 04:21 AM
MB's Avatar
MB
Member
Are you sure it's not the battery? I've heard that before!
They go very quickly.
What is your immobiliser light doing?
Old May 13, 2008 | 04:24 AM
mugen888's Avatar
do the electric window auto switch work ?
Old May 13, 2008 | 04:30 AM
juventino's Avatar
The electrics are all fine (roof, windows, lights) - I tried starting it on a flat battery once and it gives a clicking sound with no turning over and the lights fade, but this time that does not happen - it turns over but the engine does not kick in.
Could it be the immobiliser? I thought when the immobiliser was on then nothing at all happened when you press the start button?
Old May 13, 2008 | 04:45 AM
aldfort's Avatar
The immobiliser inhibits the ignition AFAIK it does not prevent cranking.
Old May 13, 2008 | 05:02 AM
nomadicS2k's Avatar
Check the ground connections, I just a similar issue on my 99.
Old May 13, 2008 | 06:06 AM
juventino's Avatar
I'll check it out - thanks.
Old May 13, 2008 | 10:22 AM
AquilaEagle's Avatar
Administrator
Could it be spark plugs?
When were they last changed, how many miles on them.
