Running the car on axel stands
I've sorn the S2000 over the winter whilst there's salt on the roads and was planning on doing a full fluid change.
I know the oils will drain a little better once warm so was thinking of running the car in gear whilst it's in the air on 4 axel stands to get some heat into the diff and gearbox.
Is this a crazy thing to do? I may even remove the rear wheels and put them under the car as a precaution, but my biggest concern is the diff and possibly gearbox running with no load on them.
Cheers
Phil
Cheers
Phil
If you're not using it why not just leave it to drain for a few days on each?
I ran mine on stands when it broke to see where the noise was coming from. It didn't get any worse
Good thinking, you're clearly the brains behind the operation!
I think I was almost looking forward to running up through the gears under some light throttle. I guess I'd be best waiting till the weather warms up a little.
I have my car on a lift (usually) for the winter with all wheels off the pavement and run her monthly to circulate lubricants in the engine until the fans activate at least twice. Also run her up and down thru all six (6) gears several times at idle to distribute the gearbox and differential oil. I turn VSA OFF (late car). Assuming the car is secure on stands I see no reason to not do this. Oil just needs to be warm, not boiling.
Caution: Do NOT turn the steering wheel while doing this. The EPS steering needs to feel resistance when turning wheel from side to side and will shut itself off which will require re-calibrating it once back on the pavement. I learned this the hard way. Info here enabled me to fix it.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
I recall both back wheels turn turn in gear but I may have dreamed this (car is on the ground at present or I'd check). LSD should make this happen. Maybe someone else can remember better than me.
-- Chuck
-- Chuck
You Shouldn't be storing cars with the wheels in droop (unless you have polly or rod ends) as it deforms the bushes because of the undue stress put on them, running them up on axle stands is fine but soon as your done get it back on all fours
Both turn, you can see both driveshafts spinning here
Think I'd better start my car and run it to get it hot.
