Quick front lip fitting Q
Old 09-08-2007, 02:28 AM
MB
Member
MB's Avatar
Default Quick front lip fitting Q
Got an OEM lip 2nd hand.
Do you just use self tappers, or do you bond also?
Thanks
Old 09-08-2007, 02:55 AM
s2konroids's Avatar
I would do both my AM one is, used silicone.
Old 09-08-2007, 03:20 AM
Shiskine's Avatar
I didn't use any bonding agent on mine. Just test fitted using the bolts to allow me to line up the metal plates for the side screws. Removed the lip, fitted the slide-on metal plates to the wings, refitted the lip with the bolts, and then finished off by tightening the screws.
Looked perfectly flush with no gaps ...
Old 09-08-2007, 04:12 AM
j8mie's Avatar
There should be two self tappers on each end (in the wheel arch), and there is something like ten bolts on the underside. You don't need to bond them together.
Old 09-11-2007, 01:49 PM
MB
Member
MB's Avatar
Gotcha.
Mine came with no bolts or screws.
Think I will just use screws on the arches then bond the rest of it...
Old 09-12-2007, 12:37 AM
Bandit_287's Avatar
They look really good.I want one but nobody makes one for a 2005,not without paying stupid money!
Old 09-12-2007, 12:40 AM
MB
Member
MB's Avatar
I think there is a company on Ebay which does them - but id want an OEM one on a MY05!
BuzzRM
08-12-2011 10:39 AM
s2000tim
05-18-2009 06:52 AM
Spoon Fed
05-21-2008 07:06 PM
ronaldng0809
09-27-2007 08:39 AM
hoangcs
02-20-2007 04:40 PM
Quick Reply: Quick front lip fitting Q
