Radio flap...........
Is yours getting tempramental? Sometimes mine works fine, other times the bloody thing simply won't open.
Any ideas what the solution is?
I have noticed the same thing. I think it was catching at the top near the vents. I pushed the base of the facia frame downwards (inside the door opening if that makes sense) and it has been OK since but I was going to have a further look if the problem comes back.
I had the same problem when I bought the car, garage couldn't fix it.
Took a close look and found there is a moulding line along the the air vent area which catches the edge of the door.
I ran the edge of a very sharp knife along the moulding to remove it.
(Knife at 90% and gently scrape the moulding line off)
Now works perfectly.
