rattle at low revs, garage near Sheffield?
now I have the hardtop off I've noticed a bit of a rattle at low revs, only seems to do it when setting off in first and when in second at low revs.
It sounds Like it's coming from under the car but could be in the engine bay.
I'm thinking it could be a loose exhaust bracket or something on the cat/heat shield. But have read a lot about the tct making noise how can I tell which it is? I haven't got any way of raising the car so it's a bit awkward to get underneath.
Can anyone recommend a good garage to take the s2000 too in or around Sheffield add I want to get the brakes checked as well?
Thanks
Thanks
I can't recommend a garage in your area unfortunately. But as soon as you get it up on a ramp if it is the CAT it will be a 2 min fix. Hopefully it is, new bolt in and no more rattle!
I had the same as k46
Any quick fit could have a look. 2 mins IF you have a bolt
open the bonnet and listen to the front of engine for tct chattering, rev up little bit and see if it lessens .
Thought it was a heat sheild on mine but was tct
Thanks for the replies, will check my messages now.
After a bit more investigation the rattle only happens at around 1000 rpm, and it does it from cold, does this rule out the tct?
My heat-shield was rattling at exactly 3.8k rpm, in 2nd gear and only when engine breaking. Sounded more like a duck quacking, the joy of random rattles.
