Rattling cat - what are my options?
Old Nov 20, 2014 | 07:16 AM
  #21
BCA's Avatar
BCA
Any issues with the O2 sensor?
Old Nov 21, 2014 | 07:18 AM
  #22
BCA's Avatar
BCA
Fitted and back to being perfect again.
The place that fitted it -renowned for their fabrication work and engine swaps- commented on how good the construction/welds were, high praise.
Noise wise, I think it's as quiet as before, possibly quieter at low Rpms? Slightly raspier at high Rpms too, only ever so slightly in both cases. I am very happy with it, will report back in a couple of thousand miles once it has bed in a bit.
Old Nov 21, 2014 | 07:20 AM
  #23
noodels's Avatar
Did you get a cel light come on ?
Old Nov 21, 2014 | 07:49 AM
  #24
BCA's Avatar
BCA
Nothing yet? Should I expect it to?
Old Nov 21, 2014 | 07:51 AM
  #25
noodels's Avatar
Cel fix used ?
Old Nov 21, 2014 | 07:57 AM
  #26
BCA's Avatar
BCA
Just used the kit as photographed?
Old Nov 23, 2014 | 11:39 PM
  #27
BenRNBP's Avatar
I've had no problems with the O2 sensor at all, no spacer/CEL fix fitted. If you look at the mounting boss on the Berk it's already spaced well out of the flow and has quite a small entry hole so it's got a CEL fix built in to the design.
noodels have you got a Berk one ready to fit or another make ?
Old Nov 24, 2014 | 03:34 AM
  #28
noodels's Avatar
63 Berk HFC been on for month or so tried service plug bridge 2 or 3 times ect
I did not disconnect battery whilst un-pluging the O2 tbh
Another member had same problem and suggested spacing out with washers
Old Nov 24, 2014 | 03:53 AM
  #29
BenRNBP's Avatar
I'm not sure I did the battery disconnect thing either, but what did occur to me is that there is quite an opportunity to break wires as the run goes over the transmission tunnel. Are you definitely getting a "catalyst below efficiency" trouble code ?
Old Nov 24, 2014 | 08:14 AM
  #30
noodels's Avatar
Dont know, have not read Cel codes yet,a must do then.what code is "catalyst below efficiency" ?
will come of road soon anyway as dont use it much due to wet weather and a first frost last night !!
On a positive note.
Had top down today as was sunny
