RE050A
I put 4 RE050's on mine before doing a few thousand miles in France. I like them; good grip and the side walls seemed pretty stiff. IIRC they are both directional and asymmetrical.
I have 225's on the rears - but when I came across an older Boxster (not s) that was running 265s I think (might have been 255) on the rears I was surprised that a very similar car had so much more rubber?!
Where's its lump though?
Also, German cars are over-runnered usually, which is why they're all roadholding & no handling.
The 16" S-02s have a 245 tread on a 225 carcass, as most forget!
Actually, I've jsut checked that:
The S-02 ES02JZ's tread is slightly wider than S02J's by about 1/2 cm on worn tyres.
It's nowhere near 245!
That's another S2000 urban myth destroyed.
I reckoned measuring them the fronts (205) were 195, and the rears (225) were 240. I compared that to the 195 Bridgestone tyres on my Primera which really were 195, so I think I was measuring correctly.
I've still got an old S02JZ in my garage, and I measured that to be only slightly smaller than the ES02JZ. So I think they pulled the same trick with the Porsche one, just not as much.
So changing to a genuine 205/225 is going to give you more front end grip and less rear. I now have 205/245, which I feared might make it more understeery but has done the opposite.
Interestingly enough, since I replaced the rears on mine a month ago with RE050As (still have S02s on the front) the car has been ever so twitchy. I was starting to think that maybe the GEO needed doing so its interesting that someone else is having a similar thing.
I was going to put an ask out on the next meet in the area, to drive it and see what they thought....
Originally Posted by Slick 77,Sep 14 2007, 02:43 AM
shepp, have you still got S02's on the front? any problems with having different rears as my rears need replacing now but I still have loads of tread left in my front S02s!
the floatyness of the car is gradually reducing with more wear on the tyres as they soften.
I could really do with a geo check, is Chris coming up North
or any other suggestions..
sorry when i mean non directional, i was refering to the tread pattern in comparison to the S02's
