Rear hub
Rear hub
What's the going rate for a rear hub assembly from a scrappers.
My rear caliper has been seizing on and off for a while now, recently its got worse (wheel to hot too touch) and the wheel bearing is groaning. I also have managed to shear one of the wheel studs.
Thinking that a rear hub replacement will be easier (assuming no seized bolts)
Thanks
Thanks
Thanks
Thanks
If that comes off, you only have three ball joints to split and you're done
Originally Posted by Hypersonik,Oct 27 2008, 08:57 PM
Well, the 36mm hub nut will be the biggest PITA!
seriously Ron, was budgies that tight? or could you just not get enough torque? not know them to rust on like that? Impact hammer? to crack it?
Gernby
08-24-2010 08:01 AM
