Rear toe arm ball joint
Im currently sorting out rust issues at rear so got rear subframe off and will de rust and underseal the shell whilst its all off..
However i have seen the ball joint on the rear toe arm has actually stripped threads and has snapped clean off as rust has weakened it.. Is there any part number for a replacement? Cheers in advance jay.. |
check lings https://www.lingshondaparts.com
Thanks buddy i have a look after dinner..
Its nakering removing whole lot on your own.. but at least it wont need doing for a while gain |
Appears its the boot thats for sale not the actual ball joint..
Any other honda ones that fit? |
Number 10
Appears only options is a replacement or go aftermarket. Ideally i like to keep it oem. So maybe need find someone with spares
A new oem arm 52340-S2A-003 isn't terrible expensive and they are the best quality you will get.
Unless you can find a used set in decent condition. |
150+vat in uk though !!
Yh saw that 150 is a bit steep.
