Removing the air pump
Remove the front bumper and nothing else
Rob, if you have any luck doing it via the arch liner, please let us know...I'm tempted to swap my defective one out in this manner
Member
Weight.
It's not something I'd bother doing tbh, it only weighs a few kg and is hassle to remove. Mine was removed when I had the car and the AEM ECU doesn't need it.
Rob, where did you get your delete kit from?
I will be watching this thread with interest because the air pump will get in the way when i make some brake ducts. Plus, everyone likes a few less kgs
Does anyone know where the vacuum pipes now go to?
There are two pipes that pass under the fuel rail and goto egr valve at the back of the rocker cover and also goto the vacuum tank and air solenoid valve?
Cheers
Cheers
From Rob @ garage R when he had his final part out sale, fingers crossed it works
