Removing Disks!
Removing Disks!
Hi All
Having real problems removing the two little screws that hold the front disks on,
I bought an impact driver from Halfrauds but its crap and isnt working.
any ideas on other ways to remove them?
Drill them out mate
You don't need them - long as you bolt the wheel on properly and tighten opposite nuts to get the wheel sat square on the hub face, all you have lost is convenience.
I got replacement screws from bnq as I did this on a sat and no were else was open. I got the right size thread with the same head , but I could get the write length so I had to cut them down. Il try and look if iv still got the packet in the garage , and let you know which 1s they were
as UF says - you dont need 'em. the wheel holds 'em on once you tighten the wheelnuts.
as you've found out this time; they'll be a nightmare to remove come next replacement.
drill the the heads off; ime the threaded part will be loose once you take the pressure off the head so fingers/pliers will be able to remove them.
