Removing Hardtop Fixing Kit
Hi there,
Any guides on how to remove the hardtop fixing kit?
Will I need any replacement parts to replace the parts I remove?
Cheers,
Jamie.
Cheers,
Jamie.
Member
Hi Jamie, you won't need replacement parts.
You will need a 10 and 12mm socket from memory.
First prise up the plastic kick panel on the drivers side and remove it, then remove the rear plastic panel behind the seats (there's a bolt behind each of the plastic hooks) Then pull the plastic panel off and you should have the side catcher exposed. Should be 4 bolts holding it in. Remove them, remove the catcher, then replace all the bolts in the same holes and refit everything. Then repeat the other side.
You might need the hole bung if you are removing the heated screen connection and loom though.
Arent the bolts longer on the catchers? Wont he need some to replace them with (cant remember)
