S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   UK & Ireland S2000 Community (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/)
-   -   Removing the lambda sensor on the cat (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/removing-lambda-sensor-cat-922131/)
mobile chicane Jan 16, 2012 09:27 AM
Thanks to s2k on roids ( top bloke ) I have a very nice original replacement for my rattly cat, I intend to unplug the lambda sensor and remove it from the original cat on the bench after I've removed the cat from the car.
I suspect the sensor will be a pig to get off are there any techniques or tricks to removing it ?
I do have a blow lamp but I dont know if getting the flame close to the threaded part of the sensor will damage it or the wiring within by means of heat conduction.
MB Jan 16, 2012 09:32 AM
Soak in Plusgas and shock force :)
mobile chicane Jan 16, 2012 09:43 AM
cool will give it a go saturday if its not raining etc
loftust Jan 16, 2012 09:53 AM
Spanner and hammer.
rob2.2 Jan 16, 2012 10:12 AM
much easier to do it whilst the cat is still on the car,
just get a large spanner and give it some force.
simonprelude Jan 17, 2012 01:57 PM
Use a special removal tool, either a slotted spanner or similar to fully grip the sensor.
But yes, soak in plusgas first.
GrittyShaker Jan 17, 2012 02:15 PM
Originally Posted by loftust (Post 21321769)
Spanner and hammer.
This was my method too.
cat5cable Jan 18, 2012 03:50 AM
i used open spanner and 7foot scaffold bar nothing can live with that sort of leverage, but yes it was soaked in gt85 overnight.
ginger
MB Jan 18, 2012 04:37 AM
I've laid under the car before, on axle stands, one foot against the wall for leverage, and heaved like mad with rust falling in my eyes to get one of these f@#kers off! :D
It's definately a case of big tools = better leverage.
Floppy Jan 18, 2012 05:15 AM
Make sure you unplug the cable first though otherwise you risk twisting the wire too much and damaging it. get the cat nice and hot from a drive first and it will come out relatively easily. Let the cat cool and then try and undo it and you're likely to chew the thread of the lambda to pieces. That what some monkey did at an exhaust centre with mine! :rolleyes:
© 2026 MH Sub I, LLC dba Internet Brands
