Replacement rear calipers
#21
Thanks Shaddow
I wait on Define198 then maybe order a pair of new rear calipers, paint them to match my old carriers, the get my dealer to install the whole shebang ( including the new front discs and pads I have lying around )
#22
didnt turn up today, hopefully tomorrow!
#23
#26
#27
Hopefully can work it out when i have them in pieces, not done anything like this before so its going to be a learning curve, do i screw in the piston as far as it will go and then re-align the cross? and by locator pin do you mean the sticking out piece of metal on the backside of one of the pads?
#28
Originally Posted by GreenmanS2000' timestamp='1435074369' post='23657435
Define
Are those the ones on eBay I listed above?
Does the actuator need to be taken off the old calipers?
Excellent ! I'll get my order in.
I guess I can live with my old painted carriers on the rear calipers
#29
It's a hard-to-find bit of info on the forum but the bleed procedure for the S2000 seems to be fronts first then rears (FR, FL, RR, RL) as opposed to the usual "start furthest from the ABS pump/master cylinder method"
While I'm here, instead of my one-man bleed pipe, I used my Pela 6000 oil extractor/vacuum pump to pull the fluid through, never done it like that before and you can't tell if the air is fully out as it sucks past the bleed screw thread, but does the job with no issues. Much better than using an Eezibleed (that you'd need the £15 multipurpose cap for plus the Eezibleed kit @ £15 in the first place) which involves a spare tyre, deflating it to 15psi, squirting pressurised brake fluid out of the reservoir cap - too much of a faff and a hazard to paintwork!
#30
Originally Posted by Define198' timestamp='1435074646' post='23657445
...and by locator pin do you mean the sticking out piece of metal on the backside of one of the pads?
