Resurrecting/restoring a track day legend
#31
#33
#34
Indeed; it's difficult to tell from the photos, but that looks like a really lucky escape.
Looks like aside from crank scoring damage done by spinning the bearing, it's really very light.
#35
so is that just a bearing failure? (excuse the ignorance)
#36
From the dirty mating surfaces of the big end cap, plus the damage to the piston, it looks more like the cap came loose, causing the bearing to get hammered and spin.
It could be that a failed bearing hammered the bolts loose, but that seems unlikely, it they were correctly-torqued and the thread speed is sufficiently fine. I know it's not aviation grade thread, but it would seem strange for Honda to make a basic error like that.
#38
Just checked the ring tolerance's from Tom's engine with the Honda manual and the top ring is well within spec in every dimension the 2nd ring is within spec but towards the service limit but the oil control rings were that far out of spec they almost fell through the bore when trying to measure the ring gap so the car would have had very good compression and good leak down test but would have supped copious amounts of oil
#40
And these are two bolts from a good rod end
