Ricks Leather Console & Boot
Originally posted by awinskill
Once I figured out how to get the LED out of the console cover (push it out and then the plastic mount gently slides off) I brought it inside to work on.
On the point above, I struggled like hell when I fitted the demister switch into the centre console... the jokers who installed the alarm LED must have pulled the wire taught when they fed it through to the control box. How exactly did you remove the LED, does it push out from below? I am loath to cut it as it is soooo tight I'm not sure there will be enough wire left to join it up again
Originally posted by Tifosi Red
Cheers for the feedback! (Sorely tempted now!)
I figured the only way the crown would come off was over the LED as I couldn't find any join in the wire. I assumed that it had to be a friction hold.... Working on the underside of the console to fit the boot with the LED fastened would have been a very tortuous process!
[QUOTE]Originally posted by Cedric Tomkinson
[B]
Guys, ( and lurking gals), Jan's Dad has been rushed into hospital and he's quite a long way away from here. He's nearly 82 so without being too pessimistic about things, we don't know what the immediate future holds.
[B]
Just to clarify the issue, mine was a joke anyway
Mind you, if I can increase the value of my car by 4 grand with Rick's console, I might just consider it ...
Originally posted by av8tor2
awinskill
In your photos, what is the button behind the cup holder?
Paul
awinskill
Paul
You mean the US cars don't come with a shower
Mine did, however, come with a wife pi$$ take prevention device
(Try it next time she gets out of the car after taking the pi$$ out of you )
